Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Sat Jan 24, 2004 6:13 pm
I don't know if this is the BEST way or not, but it's certainly a pretty safe one: Get a good dino oil (Castrol GTX 10W40 or so should be good) buy a case of it because your going to need it (just bought a case, 22 dollars). Start your car up, bleed the coolant system, check belts etc, and let it run at about 2000rpms for 20-30 minutes then drain the oil, change the filter. Run the next batch of oil for 50 miles before you change the oil and filter again. Refill and then run it until 500 miles, while not revving much over 4000rpms and not holding any prolonged higher rpms. At 500 miles, drain and replace your filter again, with dino oil still and run it for a good 3000 miles, after 1000 you can start revving it and driving normally again. After 3000, you can switch over to a full synthetic if you want too. This is the break in procedure I'll be using, as recommended by the machine shop that built my motor. The only difference is I'll run a thicker oil since it's now a KA-T.
