Details on the copper line? Do you remember what all you used? Thankseazye2000 wrote:Mine snapped off in the oil filter block, that bolts to the engine. I wouldn't recommend it.
I took out the stock sensor, and ran a copper line to my firewall. And then there, is where I put the 'T' and hung it off the firewall for better support. I don't think I have any pictures.
Forgot to add, that I have the steel 'T' in the block. One goes to the engine, one goes to feed the turbo, and the other goes to said firewall contraption.
no no no I did it like thisblock__straight fitting___hose__T fitting__oil feed__pressure senderFlorida240sx wrote:You can't use a t fitting to go into the lock you need an adapter. clock is bspt sandard brass fitting is npt
I have to use to stock sensor unless I get a plug for it, which isn't a bad idea, and I wanted to use copper line (which didn't come wiht my autometer gauge) because it takes weight off the tee. But it turns out my tee is steel so that's good.Biggamehit wrote:not hard at all bro... takes all of what 5 min to install it... who cares about the stock sender when you have a after market accurate gauge. if your stock sender light comes on anyway lol... your to late with a boosted application
now that copper line jazz is not needed.. that sender will fit without all that .. i know it looks tight.. but i have a even smaller T and the sender doesn't touch the block at all
It works beautifully. Just clutters the firewall a bit more. I can snap pics in the next day or two. It's supposed to snow like a hizzore..redhb240SXS13 wrote:I just re-read eazy's post. I love that setup, probably going to do the same.
