Brand new T3T4 installed
20DET
howsit...just installed a brand spanking new t3t4 on my rb20det...i am running the turbo on the factory manifold with external wastegate and a 3 inch turbo back exhaust.....i just put the oil line on it now and started it 4 d 1st time....was just wondering..... wen its on high idle the turbo is spinning...wen i rev it its spinning...but wen it idles at 700rpm the intake propellor stops...and wen u rev it up it gets going again...is this cos the turbo is brand new or wat
any help would b apreciated
robbie2883
Car: 1998 RB25 Kouki
all depends on the size of the turbo and the amount of air being moved by the motor at low idle. it's normal as long as you know you're getting oil to it you'll be good.
20DET
thanks bro...its a t3t4 .50 trim...yup its geting oil pressure...cos the fitting was leaking...put some thread tape on it and now its away with no leaks...so its because at the low rpm the exhaust gases arent strong enough to spin the turbo???
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
yup thats right. the bearing style has a little to do with it too. Ball Bearing spins very easy and will even keep spinning after the engine is shut off. you have a journal bearing turbo though so it wont spin like that.
20DET
ah yes thanks....one other question...its a brand new turbo out of the box...i drove it a bit yesterday and the most i gave it was 8psi...was wondering if u have to run in a turbo??? or can i give it death and buz out at how fast it is?
DrifterProdigy85
I cant really understand what your asking but i think your talking about breaking in the turbo. Like any new moving part i part on my car, i try to give it a couple hundred mile break in period. So with the turbo, keep boost low for the first couple hundred miles then i would gradually start turning the boost up to where you want it. id be carefull though if your not tuned yet for the setup.
20DET
ok sweet as mate cheers
