distant240sx »
https://forums.nicoclub.com/distant240sx-u59878.html
Sat Nov 24, 2007 10:35 am
Alright, i cheked all my grounds(good) , vacuum lines(good), fuel pressure is at 40psi when i try to start the car, Injectors all click, But compression is at 60psi first piston, 70 psi second piston, 90 psi third piston, and 60 psi fourth piston. Is the compression right? it has new piston rings, they where installed and align acording to the manual. i heard it should be around 151 psi, when the car is warmed up, but does this sound right when the car has not yet been started???
