evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Feb 06, 2009 10:38 am
sounds liek a great project, the rear brakes are siezed either because the e-brake was left on and the lever rusted in place ont he backing plate, or the cables siezed up, or if the braks was left off then the pads corroded to the aluminum rear drums, either way removing them will be a PITA but a necesarry PITA#1 drain and replace all the fluids, Oil and filter, gas and fuel filter, coolant, brake fluid, cluthc fluid, diff oil, trans oil#2 pull all the spark plugs, spray a bit of wd 40 down each spark plug hole#3 disconnect the positive side of the coil as well as s the injectors or the injector relay, top off allt he fluids, and with the plugs still out, crank the engine, let it crank for 30 seconds or so, put in new plugs, reconnect the coil and injectors, crodss your fingers and hit it
