doubleohkevin »
https://forums.nicoclub.com/doubleohkevin-u94557.html
Thu Aug 27, 2009 8:50 pm
Hey nico I just installed my sr20 swap a few days ago and got everything bolted down and such, but the clutch is slipping at anything past 1.5k. I have adjusted the pedal and the free play via the bolt and rod behind the pedal so the engagement point is fine. I can definitely feel the clutch slipping easily and when i accelerate really slowly it seems to catch better.
I suspect there MIGHT be some grease on the clutch or something, i DID put some grease on the end of the transmission shaft when inserting it to get it to slide into the pilot bearing easier.. perhaps that was a no-no. Otherwise, the clutch is brand new oem spec, the presssure plate is as well, flywheel was resurfaced....
I was also wondering if it would be possible to just run it very lightly to burn up the oil/grease and hopefully the clutch would be okay? Or is it possible to take both clutch/flywheel off, clean it, and reinstall? or do I need to buy a whole new clutch and get flywheel resurfaced again?
btw this is an s13 sr20det in my 1995 s14.
Any help would be greatly appreciated.Thanks!kevin
