Mark Mellott »
https://forums.nicoclub.com/mark-mellott-u229493.html
Thu Jan 02, 2014 8:41 pm
I have many occasions of this happening to me as well. On older cars, the pulleys get get glazed to a highly polished-like condition over the years. The pulleys are fine but the "polished" surfaces of the v-grooves against the rougher surfaces of the new belts can tend to squeak a bit, especially when it is cold outside. This squeaking can go away on its own over time but it can also get worse depending on the type and brand of belt that you have.
There is an easy fix for this. Be sure that your belts are tightened properly. Not too tight, as you indicated they might be now, and obviously not too loose. Purchase from your local automotive parts store a spray can of belt dressing. It's sometimes called belt conditioner. This needs to be sprayed onto the contact surface of the belts which is sometimes a bit tricky when they are already installed. The spray cans usually come with a spray nozzle tube. With the utmost care and caution, with the engine running, spray the product onto the belt side that contacts the pulley. First, see that you can get a good spray angle to any part of the belt, without putting your hands or the can dangerously close to other belts or the fan. While the engine is running, spray for a couple of seconds without moving and you will have covered the entire belt. The squeak should immediately stop.
If in doubt of your safety at all, do not run the engine. Simply try to spray the entire belt as best you can. You won't be able to get every part of it covered but it will probably be enough to take care of the problem.
