Brakes z32
sgreen
Car: working on my car
I am about to buy 300zx brakes off this guy for my 92 240 and i wanted to ask a few things before i did. I am going to buy the fronts and rear calipers and rotors brake lines and master cylinder for 200 dollars. They are coming off of a TT with 80k miles on it. My question is will the rotors work fine if i get them re drilled. And can i put the rear z brakes on as well. Can some one tell me what i need to do to make all this work. thanx let me know
SoCalS14
Car: My car...duh
Be sure to buy the E-Brake assembly if you want a functioning E-Brake...They are a little more work to tak eoff and put on...
hannibal
Car: Red Line to Glenmont
if you get them redrilled, the front and rear should just bolt on.From what I understand, the Z32 e-brake is part of the rear rotor. You would have to splice your S13 e-brake-cable with the Z32 cable.The brake lines will need a different connector on the end that attaches to the body. Bascially you need the the fitting from the body end of the S13 lines and the fitting from the caliper end of the Z32 lines.Theres a sticky in the Brakes, Wheels, Suspension forum...
