brakes wont bleed?
S1d3way
Car: 1991 240sx
91 240sx non abs
1st I broke a rear brake line, not a big deal i replaced it and bled both the rears but the brakes were still squishy so after talking to some people they said i should bleed the fronts too. i jacked the car up, had a helper pump the pedal, cracked the drivers side front bleeder and now the pedal wont get any pressure. we bled that caliper for alt least 20 min and it got no better. i have never had this problem before with brakes. Any ideas??
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
If the master completely ran out, there is probably air in the master. Gravity bleeding is the best way when you have air.....then go back to bleeding by pumping, holding, bleeding.
biggie
Or a one person bleeder, either manually pumping, pressurizing a remote res, or air bleeding.
S1d3way
Car: 1991 240sx
it didnt i kept it above half full the whole time. another thing thats weird is when the brakes are pumped the fluid in the reservoir bubbles.
compactfean
daily
Then that means you have air still in the master. It must have happened when you fixed the brake line.
S1d3way
Car: 1991 240sx
ok ill give it a shot. thanks!
DriftFingerz
Car: 1990 s13 coupe-sold
1990 mazda miata-sold
1995 s14 base-sold
1995 s14 se sr20det-sold
1995 s14 kouki conv sr20det-sold
1992 s13 coupe-sold
1989 s13 hatch sr20det-sold
1992 s13 vert FTW-current
when you bleed brakes you always start with the wheel farthest away from the master cylinder so you would go rr,lr,rf,lf, if you replaced a line more than likely a good bit of your fluid leaked out so its gonna be a b**** to do... i would suggest a solo act at it not sayin it cant be accomplished but two people makes the process way easier .... and compactfean i agree gravity bleeding is my fav but the process is way longer
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Its actually drivers rear, right rear, right front, left front on USDM S-Chassis
