For the past 2 years, around every 1-2 months, I would have to top up the brake fluid, around 20-30 mL. A couple weeks ago, my brake pedal sunk to the floor, but when I pumped them the pedal would be nice and firm. So I tried to bleed the brakes, had no air except for rear right caliper. There were bubbles showing up constantly.
So far, I've replaced the Master Cylinder with a brand new Z32 one, removed ABS, rear calipers and the rear hoses, the calipers were kinda damaged and the hoses had never been replaced.
After using a MityVac to bleed all four corners, I would still get air in the rear right caliper, put some thread sealant on the bleeder, still air. So I used a hose with a check valve and managed to bleed it till no bubbles came out. I guess the MityVac must have been sucking air through the bleeder threads.
So for bleeding I have:
Bench Bled the MC
Gravity Bled all four calipers
Used a Mity Vac on all four corners
Used a tube with a check valve to bleed it
I've gone through 2L of brake fluid trying to bleed it
Also, the vacuum gauge on the MityVac slowly creeps down, from 25 to 20-21 when I bleed it and stays there.
The pedal is slightly firmer, but there is barely any stopping power, the tires do not lock at all on a wet surface.
Anyone got any tips on how to deal with this?
Thanks
EDIT: Stock brakes on all four corners.
