benemorius »
https://forums.nicoclub.com/benemorius-u17066.html
Tue Jun 08, 2004 6:23 pm
'90 240sx - no ABS
My friend recently got this car and saw no problems, but I am not impressed by the brakes. From my limited experience, it feels very much like glazed pads. However, the pads, master cylinder, and booster have all been replaced and there is still no difference. (they need replacing anyway as the pads were in fact glazed, and the master cylinder had filled the booster with fluid) I have also properly bled the lines, and replaced the fluid while I was at it.
I have even tried new rotors and calipers just for grins, though I'm back to the old ones as that did no good. So, the only thing that I know of that is either not new or hasn't been made new temporarily is the brake lines. What can be causing this? Surely this isn't normal or something? I realize some cars just have different brakes, but I can push frightfully hard on the pedal and still not lock up the wheels.
I'm tired and aggrivated, so if I've left something out, please be forgiving.
umm...in case I wasn't clear: The brakes just don't feel as 'grabby' as most cars I've driven do. When I push the pedal down, it goes down a bit before the brakes kick in. I feel as though I must puch as hard to stop from going 40 as I normally would to stop from going 70. I would not call the pedal 'spongey', and applying constant pressure does not cause it to sink slowly, however I can push it all the way to the floor, given the aid of the booster.
