calsettle »
https://forums.nicoclub.com/calsettle-u303122.html
Sat Oct 09, 2021 2:31 pm
2015 Nissan Juke SV (canada). Just replaced all the pads, rotors and rear calipers. Bleed the braked using the factory procedure. (discounted battery, and used the Criss-cross bleeding as specified). Problem, on the first depression of the brake pedal it goes straight to the floor. If I pump it 3-4 times it will hold firm. Could there be anything other than air in the system? I'm not seeing any air bubbles while bleeding.
Any suggestions welcome.
