brakes
anou
alright check this out. i got some rear 300zx calipers and i was wondering if they would mount right onto my rotors? thanks
book-ends
Car: ???? Nissan 240SX coupe S13
Onto the stock 240 rotors? I don't think so; the diameters might be different enough that the caliper body would rub against the "hat" portion of the disc.
Why not just unbolt one of the rear calipers and see for yourself? It shouldn't take more than ten minutes and you wouldn't have to bleed the system or anything.......just have a friend hold it for you while the brake line is still connected.
180fan
Car: 89 fastback
not onto the rotors. way different thicknesses. the caliper's bolt up onto the knuckles without a problem but you'll need new rotors to make em work
book-ends
Damn,
I completely forgot about the difference in thickness as well!
black s13
and you wont have an e-brake...
