Brakes
nismo696969
In my 95 s14 my brake light comes on when i hit hard bumps or a hard launch and stays on for a while then goes off?If anyone could help much appr. thanks
black s13
fill your brake fluid.
nismo696969
Already checked it and filled it.
black s13
the only 2 things that turn that light on are the sensor in the brake fluid resevoir, and the e-brake. theres gotta be a short to ground somewhere or something like that.
nismo696969
ok i will check that. thanks
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
agreed, did those work for you?
Nissan-S14
Car: 95 Nissan 240SX SE
change your brake pads maybe?
ziggy682
Car: 1991 240SX Turbo
Nissan-S14 wrote:change your brake pads maybe?
I hope you're joking.
nismo696969
well checked it was grounding out. One more question i have 4 lug in mylocal junkyard there is a se what do i need to take off it to make mine 5 lug besides the rotors?
nismo696969
nevermind found it.
motoki
Take off the hubs and that's all you'll need since you have an s14.
