kuhan wrote:What I recommend is that when buying an used Brembo bbk, make sure you get a rebuild kit to replace old gaskets, etc.
^ ^ This ^ ^
kuhan wrote:Yes, the ranges are actually between $1000 - $1500 for the whole kit. You can find just the calipers in good condition for about $600-700.
If I were upgrading to the OEM Brembos I'd just get the calipers, a rebuild kit and pick up everything else (pads, rotors and lines) brand new from an aftermarket provider. I've recommended them before and I'll do it again, I've got nothing but good things to say about the stuff I picked up from
RacingBrake out in Fullerton.
While the calipers were out I'd fix any nicks and chips they had and maybe even get them powdercoated so after a rebuild they would be in a like new condition.
And not that it's a big deal to most people but keep in mind that when you upgrade to steel lines you'll be bumped out of Stock classification if you were planning on autocrossing your car. Can you believe that we've got cf reinforced driveshafts but don't have steel braided lines?
There is one other quasi-OEM upgrade that you could do. I've only seen it a couple of times, but you can mount the MASSIVE Akebono brakes from the 370Z Sport Package on the 350Z. You'll spend more simply because of the size of everything, but I can't imagine these beasties ever not being up to any task you might throw at them.
