BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Fri Jan 23, 2009 2:39 am
Mightyversa is right, As for warranty coverage, brake pedal pulsation under a certain mileage *MAY BE* covered under warranty. This is due to warped rotors, which shouldn't happen until the car hits 30-40,000 miles (which wouldn't be covered).
Brake pads at the dealer are about $65-$70, rotors (for both) are nearly $300.
If you have never done brakes before, buy a Haynes manual for a comparable Nissan product (Sentra is close enough) or a Versa if you can find one. Read the entire brake section before you do ANYTHING. Brakes are easy, but if you don't even know what a C-Clamp is, perhaps you should leave it to the professionals, eh? I say this because the job also requires you to understand proper bolt torque, PROPER use of cleaning chemicals (Brake cleaner), correct placement of pad retainers (this can be tricky on some cars), amongst other things. Why risk your life and others because you want to save a buck?
