odpl_Digger »
https://forums.nicoclub.com/odpl-digger-u110513.html
Wed Dec 31, 1969 5:00 pm
I have one rear brake that is dragging and I can't figure it out. I recently replaced the wheel cylinders, brake shoes, and all springs on the rear two wheels. After reassembling the brakes, adjusting the shoes, bleeding the lines I noticed that when the wheel was turned in the backward direction it spun freely. However, when turned in the forward direction it would stick -- get stopped by a brake shoe. I tried swapping drums but the effect was the same. I removed and examined the new shoes and even sanded the edges to remove any sharp edges or burrs. I swapped the position of the shoes. All to no avail. Everything appears the same as the other side, which operates without dragging. On the problem wheel I noticed that the adjuster housing slides easier on the problem wheel than on any other wheel. I tried bending the adjuster shim to create more resistance (though I did so without completely removing the shim and lock plate) but I'm not sure that increased resistance much. I still have the drag -- only in one direction. I'm tempted to remove the after shoe return spring, but I'm not sure what problems that would cause. Any advice or ideas??? Thanks
