brakes
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
upslarry
I have a 05 G35 sports coup. I do not have the brembo brakes, however I do have the sports package suspension. I attepted to get new brake pads and the aftermarket pads did not fit. The parts man at NAPA said the the pad I had was from an M35. The Nissan 350Z pads also fit, but the wern't available in ceramic! Has anyone seen this issue before??
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Brembo brakes were only available on the 03 - 04
Its not likely that someone as switched out the brakes to M35. If they are going to switch out brakes they would normally swap to the brembos or a BBK.
My guess is that NAPA had the year wrong on your G.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
