C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Jun 24, 2008 10:01 am
It would be tought to assess exactly what is going on with your brakes without being able to do some scientific testing on your brakes. The post I made was to give you a bit of insight into some possibilities. From that, you may be able to try and figure out if there is an actual issue that I described that might be causing your brake issues, or that it might have occurred before you took ownership of the car.
One common situation where the problems I described can occur, even with normal drivers is when someone lives on a long steep hill. Some drivers will ride the brakes all the way to the bottom where they stop at the end, and have to hold the brake while they wait for a green light or for a space to pull out onto the main road. More typical driving situations should not cause this issue. I brought it up in your case as you indicated that you had a pulse prior to your brake service that has now returned, which is typical of judder that occurs when cementite has formed.
The OE brakes on the 06 G35s are more than adequate for performance driving. They are bigger than the 03-04 brakes and even those were pretty good. The 06 brakes are nearly as large as the Brembo brakes. Short of some serious track use, there really shouldn't be that much of an issue. One could easily ruin a good set of very large Big Brake Kit brakes by putting a lot of heat in them and then holding the brakes at a stop or while parked as well. While larger rotors will inherently be subject to lower temeratures for a given amount of braking energy absorbed, the issue I speak of does not necessarily occur out of overheating the brakes. It can occur well within the heat range of your brake pads.
