whowutwut »
https://forums.nicoclub.com/whowutwut-u14197.html
Wed Jan 09, 2008 12:29 pm
I've never had to bleed the Master cylinder on my car and I didn't know you could do that!! But after bleeding the MC, i think you should still go back and bleed the lines so you get any air out that might be between the MC and the calipers.
It would make sense to bleed the MC the same as the caliper. pump, hold the pedal , loosen the bolt (AND re-tighten before letting go of the pedal!!) If you let go of the pedal before tightening the bolt, air will get in.
