whiterps13 »
https://forums.nicoclub.com/whiterps13-u9007.html
Sun Dec 02, 2007 10:29 am
Whats your budget?What do you use the car for (street, track use)?
If you only street the car then theres no need to even upgrade the calipers. Just get some Hawk HPS pads, some stainless lines, and some new brake fluid and you will be good on the street. I run this setup and cant realistically fade 'em on the street.
If you need something more than that, you can upgrade to Z32 calipers. This is also a pretty tried and true setup and can be done for around $500 for all corners.The only problem is converting the e-brake to work with the Z32 drum.
If you seriously track the car (hardcore time attack, road racing) or just want a big-brake upgrade for looks, Id look into Stoptech, Rotora, or SPL sells some kits to use Z33 rotors with Z32 calipers.
