Brakes?
skylinedreams
Car: 90 240sx
I've searched on this and havent been able to find much. I need to change my brake pads and rotors on the front of my 240 (90). I just want to know how much torque do i use when im putting the caliper back on. that and to get the rotor off the front do i just unbolt the caliper and pull the rotor off?
240ight
Car: 90 240
hey im doing my rear on the 90 240 i was trying to get the caliper to go back using the c-clamp but it screws in it has 4 point use needle nose pliers and twist it in maybe you already know but it took me a while to figure this out anyways i cant seem to get the rotor out should't it just come out once the caliper is out or is it bolted some how maybe its just rusted in there anyone know?
SimpleEnigma
Car: 1992 240sx Coupe
the hub and rotors are separate on the 240, i.e. the rotor just slides over the lug bolts, so once you remove the caliper retaining bracket, you should be able to remove the rotor no problem.
95nismo240
Car: 1995 Nissan 240sx
hit the middle of the rotor with a BFH and it will pop right off
sanioll
Car: Nissan 240SX SE
Toyota Camry
use search button on the upper right of this browser. its very helpful
as for how much torque? just make sure its tight enough with a foot long wrench, thats all, dont force it too much, just tighten it with your single hand as tight as your can push. well if youre too strong , dont force it.
you can find a service manual for download here too. just use search..
240ight
Car: 90 240
I finally got my rotors to come off they were a bit** they were rusted in there pretty good so i drove my 240 today and it feels fine
