Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sun Sep 24, 2006 4:18 am
Once a braking system has seen 100k plus, always consider it may be time to clean up [inside of piston and bore] and replace the piston seals on the calipers....................depending on frequency of fluid exchange.
The shim kits have a finite life, also the flex rubber brake hoses, master cylinder, etc.
Expecting as new published stopping distance depend on the components [tires and brakes] acting as brand new...................this gets more and more difficult as the miles pile up.
A few components each acting at 95% of new can quickly add up to a 125% braking distance! 129 feet new can easily turn into 160 feet.
