aft981 »
https://forums.nicoclub.com/aft981-u98521.html
Sun Jul 26, 2009 7:36 am
I know I do put more than average miles on my cars, but I am a little disappointed how quickly I've had to replace certain parts. I'm currently at 33,000, after 14 months of ownership.
At 28,000 miles I got 4 new tires.At 32,000 miles the other week the rear brakes were replaced.
My prior vehicle was an 04 Murano, which was subject to identical driving patterns, and after 3 1/2 years and 125,000 I had replaced the tires twice, and the brakes twice.
Also, back in Feb of this year, I had taken the EX in for a service, and complained that at hwy speeds the car was vibrating. They retooled the front rotors, and that seemed to fix the problem. That was at 20,000 miles. Again, when I took it in for service a few weeks ago, I mentioned it was vibrating at hwy speeds again. I was told the rotors needed retooling again, and it wouldn't be covered under warranty this time.
Obviously not what I wanted to hear, so I complained, and told them to check when I had last had it done, in Feb, and told them I shouldn't have to have the rotors retooled every 10,000 miles, which is ridiculous. I asked what circumstances would lead to the rotors becoming warped like this so frequently, and he told me its often heavy braking when the brakes are hot, which I knew anyway. He said they had had no reports from Infiniti of faulty rotors on the EX, but as a courtesy would install new rotors at the front, under warranty.
The vast majority of my driving is on the hwy, and my route to-from work avoids rush hour and avoids traffic. It's an easy 30 miles on the hwy each way, where I normally pop on cruise control. I don't do any heavy braking, no more than I have in prior vehicles I've owned.
This got me thinking, I have the ICC and the LDP, which I frequently use. Both those systems use the brakes at hwy speeds. Steve, do you know if the LDP uses just the front brakes to keep you from drifting, or does it use front and rear? The ICC also uses the brakes more often than I would if I was just cruising the hwy. Even though it can 'see' the car infront from quite a distance away, it doesn't seem to simply let up on the throttle and gradually bring you closer to the car infront, it carries on at your set speed and then hits the brakes when you get to the set distance.
1. Forgive me for being cynical, but Infiniti must have thought of this when designing the systems, and knew both systems would prematurely wear down the brakes and force you to replace them more frequently...more $$$ for them.2. Could frequent use of the two systems be causing premature warping of the front rotors, and if so, is this a design flaw?
Thoughts anyone? Anybody else use ICC and LDP frequently and have many miles on their EX yet?
