pntang wrote:use a needle nose plyerit'll take a while but u have to turn it to get in back in place...oh and make sure u set the pin on the new pads right w/ the slots in the caliber...if not u'll have rubbing and wearing problem...no to mention ur brakes wont work right...that means no drifty drifty
this is how i did mine , and yes he is right about the pin i had to learn the hard way HAHA
before replacing the pads make sure you sand those rotors if ur not gonna resurface um.KA_Pig wrote:My rear discs on my '89 coupe have started to squeak badly. I inquired at Strauss where I usually get my "everywhere grays" and they said that to change the rear brakes, there is a special key Nissan has installed to prevent owners from changing the brakes themselves and having to take it to a stealership. I have changed my front brakes twice already with no problems but just as a heads up, is there any difference at all to changing the rears ? Will I have to acquire this "special key" from Nissan ?
The piston tool.Lost_In_Translation wrote:You can use pliers if you want to. But you'll be better of buying that ''key''
The C-clamp is just used on the front caliper which has a push-type piston whereas the rear has a screw-type piston.KA_Pig wrote:No C-Clamp required, huh ? How do I know how far to twist it before I push the piston in too much and ruin the caliper ?
