Brakes not locking at the same time?
float_6969
Ok, so I've got a 4 wheel 300zx brake upgrade w/mastercylnder. Here is my problem. My drivers front brake locks up before my passenger front does. I know they are bled correctly as I've done it countless times. Anybody else have this problem? My thinking is that since the mastercylnder was orignally designed w/1 line for the front, splitting it may have messed up the balance. Also, the Z32 had (what I call anyway) an equalizer line between the front brakes, assuring that they had equal pressure. To fix this I've thought of either getting a brand new MC and then modding it to get it to work again, or to build and equalizer system into the front brakes. Any input would be greatly appreciated!
C-Kwik
It's possible the traction at both front tires may not be the same. If your right front tires carries less load under braking, it will lock up first.
Mayhem_J30
Car: Ummm...My Car
Do you have the same tires on both sides?
Dori Dori
Car: Cars of course
Shorten your sig dude, please!!! :oy:
Exar-Kun
Car: 2005 350Z
why did you have to split a line?spliting brake lines is a bad...bad idea. it can mess up the proportioning from side to side very easily.-chet
Hijacker
Car: '92 240sx Convertible
'94 F-150
the Z MC's were designed for ABS, so they normally have one line for fronts and rears. But they also have a plugged valve for the second front line. You did pop that out and put the front line in it, right?
float_6969
C-Kwik - I suppose it's possible, but if anything the other wheel would lock up because I'm sitting right behind the wheel that is locking up.
Mayhem - Same wheels and tires all the way around
Dori Dori - I have a title to maintain, "The longest texted based sig on NICO". People like me are the reason that your sigs only show up once now! I'm so glad I have an influence on NICO. Hehehe
Exar Kun - I had to pull the plug out of the Z32 MC. Originally there was one line for the front and one for the back and then a plugged up hole. I unplugged the hole and used that for my other side.
tenkawa_akito - Yes, I did use that line. I'm wondering if that is where my problem is at?
