Fair enough. If you're looking to go non-OEM, ask whyceningolmo wrote:Wes told me the rotors are warped. And, Wes' opinion is good enough for me.
True if you can match the life/performance of OEM, for less $$, it's the right thing to do. Might doa search for different brand names of rotors as in post text by Q45Tech.ceningolmo wrote:Everyone seems to like the Brembo...and, based on the threads I have read, it sounds like they are OEM or better performance. And, they are about $20 cheaper per rotor than OEM rotors from Scottsdale.
I don't need anything that exceeds OEM performance... I don't drive hard enough to warrant anything beyond the already good stock performance. But, if I can get the same or better performance for less money... well... I am working with a budget here!
Cheapest place for the lines is... http://www.competitionwarehous...d=563 ...you can pick em up for $89.00ceningolmo wrote:DOT 4 fluid? Can I pick this up at the local Autozone?
Stainless steel lines... what would be the least expensive source on these?
But as Q45Tech has said, it's not just weight, but the quality of the ore to produce them for truely be the same.elwesso wrote:If you go with I rotors, dont get the drilled... Cheap+drilled=disaster...
The key is to make sure they weigh similar to OEM...
I have brembo blanks on my Q and im happy!
zerothread?id=110515Rex wrote:Also, I would only consider upgrading the lines if I was replacing them. Ffew on here really drive their Q hard enough to justify upgrading just for the sake of upgrading, but it's their money, not mine .
whatchu talkin bout!Rex wrote:Also, I would only consider upgrading the lines if I was replacing them. Ffew on here really drive their Q hard enough to justify upgrading just for the sake of upgrading, but it's their money, not mine .
Just the plain and simple truth.elwesso wrote:whatchu talkin bout!
