Brakes make a springy noise
Neejay
When Im at an almost stopped speed, or like backing out + braking, my brakes make a loud spring noise. Like a poping/compression of a spring. Anything to be worried about? Is it also normal for my wheels to squeak at different times per braking?
Nismo_Freak
Car: 89 Nissan 240SX
Tension rods more than likely.
Neejay
Nismo_Freak wrote:Tension rods more than likely.
How would that work out? Just from braking? Shouldnt be the bushing, because I replaced those around this time last year with ES urethane ones.
Neejay
anyone?
Nismo_Freak
Neejay wrote:How would that work out? Just from braking? Shouldnt be the bushing, because I replaced those around this time last year with ES urethane ones.
Check the bolts to the lower control arm, retorque them to proper spec.
Tension rods prevent for and aft movement of the wheel under braking and acceleration.
