robomatic12 »
https://forums.nicoclub.com/robomatic12-u138186.html
Mon Jan 24, 2011 12:53 pm
Attach a clear line to the bleed screw, then grab a friend, pump the pedal a few times to build pressure, hold the pedal down and tell your helper to open the bleed screw. Then after the fluid has come out, close the screw and you can lift the pedal again. Repeat until you see clear fluid come out of the bleed screw. Do it in the correct order including the ABS pump in the service manual available online.
