im looking into j30 or Q45 brakes, since they are easy and cheap to find at a junk yard, and from what ive heard are significantly better than the stock brakes, and are a worthwhile upgrade, especially in my case since my stock brakes pretty much dont do anything at all
ive heard the 97-01 q45 brakes are bigger than the 91-96, and you have to modify the bracket or some holes to make it fit. Im going for the cheapest and easyest installation, without cheaping out, so ill pass on those
my question is, are there any real differences between the 91-96 Q45 brakes and the J30 brakes? Ive read the j30 brakes are slightly smaller, but ive also read that Q45 brakes throw off your brake bias, so maybe the smaller j30 brakes would actually be better? Anyone got any input on this?
the other thing im wondering is what have you 4 lug guys that have done this upgrade done for the rotors? From what i know theres 4 options
1: re-drill the rotors i get from the junk yard
2. buy em new for $30 at advanced and re drill them
3. buy brand new cross drilled and slotted 4/5 lug interchangable rotors (i dont know where they sell these but i know they exist)
4. use the rotors from the 95ish altimas, which have the same diameter, but are slightly thinner (would this be safe?)
and does anyone have any info on the M30 brakes? from what i know these are 4 lug rotors, but the caliper is only a single piston "floating" design, which i have no idea what that means
supposidly they still have a lot of stopping power, evern though they are single piston
thanks in advance for any helps
edit: apparently another option is the "180sx spec upgrade"
which is basically 3rd/4th gen maxima brakes with 94 altima rotors
...and according to this guy, the q45 brakes clamp too hard and are liken on/off switch
http://www.sr20forum.com/240sx/180348-q ... -ever.html
