I would also use the old brake pad as a board to put pressure on the piston more evenly. plus you can avoid a slip off or what have you.newnissanfanatic wrote:The easiest way to compress the piston without damaging the outer portion is with a C-Clamp. I have done this on other vehicles in the past.
You wouldn't You bleed the system AFTER the pads have been replaced and the caliper is mounted back on to the rotor.94fordman wrote:how would u compress the piston on the caliper while bleeding the system put c clip around caliper with brakepad and push brake peddle or just crack bleeder a little and compress
