maka »
https://forums.nicoclub.com/maka-u38035.html
Mon Aug 28, 2006 3:41 pm
I have an S14 and my brakes are doin something that i have never seen before. they are making thick chunks of brake dust. i have a lot more obvious brake dust on the rear than the front. shouldnt it be the other way around.
i had also just change my pads cause of normal wear, and that was the first time that i had encountered calipers like that, for a few minutes i thought my piston had frozen, but i figured it out. is there suppose to be some sort of maximum or minimum to screw the piston in when installing the new pads? cause my brakes are starting to squeak and STILL make thick brake dust on rear wheels. is there something about these rear brakes that i should know.
just a little of what happens...
my breaks ware unevenly(rear driver inside pad was down to the metal)
after changing pads, i screwed the piston flush.
still squeaks after the car sits for a little(as if it was hitting the wear tab), but, when i press the brakes for a while while in motion, it seems as if it warms up and does squeak ONLY once in a while..
is there anything that i am missing.
