T-Indy »
https://forums.nicoclub.com/t-indy-u195424.html
Tue Apr 03, 2012 8:15 pm
Twice in the last two weeks the brakes on our 08 QX56 have had this problem. When slowing the vehicle to pull out of the neighborhood, brakes grab and grind like the ABS is coming on. Seems to only come from one front wheel. If the vehicle is turned off and back on, the brakes operate normally. In a quick google search this seems to be fairly widespread issue with both the Armada and the QX56, including some cases of complete failure! However, I haven't seen much on it here and there doesn't seem to be a consensus on what the correct repair is. Has anyone else experienced this problem and had a successful repair?
