branmr2 wrote: the front calipers are 4 pistons from a silvia the rear are stock.
Spongy is a relative feeling. If you are running that setup w/ stock master cylinder, you will definitely get "spongy" feeling. Pumping the brakes w/ the car off should make it stiffer than normal, that's how it works.
Is it spongy, but still stops? If it hits the floor, you have a problem, if it is just soft but stops decent still, it's just because of your setup.
To "fix" it, if I'm correct. You need to at the very minimal change to z32 master cylinder - ideally z32 master cylinder + z rear brakes.
