Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Mon May 02, 2005 4:54 am
Mark, thanks for the props on the strut bar.
Did you try to adjust the rear ebrake drum? I have bougth rotors from iRotors before, and they fit fine. The ones on the front of Layla are the iRotors ones. I have 60K miles, and have not had any vibration yet. I ahve been through 2 sets of pads, though. The rear cracked, from overheating though. Not really the rotor's fault. I had a caliper sieze on the interstate about 10 miles from the house. Once the pad was gone, it was metal on metal, and sounded like I was dragging a trailer. I had no tools with me, so I forged on, knowing I had already ruined the rotor. I was able to get the caliper un stuck, but every time I used the brakes my hair would stand on end. When I got home, the rotor was well over 600 degrees and cracked like a burnt flywheel.
Get yourself some speedbleeders, to replace the bleeders on all 4 calipers. They are about $12 a pair. It allows you to bleed the brakes without a lot of hassle.
I went through 2 quarts of fluid in about 20 minutes, and flushed my brake system completely. First, with some clear CarQuest DOT4 fluid, then with a quart of ATE Superblue. I used a juice bottle, and about 12" of clear hose. Once the fluid ran clear, I knew it was flushed, then I went to the next wheel and did the same. I went in this order: RR, LR, RF, LF, then I repeated it with the blue fluid. Once it turned blue, I knew it was completely replaced.
By the way, is that the Right rotor, on the left side of your car?
JK, I just thought I would make you look.
