OwnerCS »
https://forums.nicoclub.com/ownercs-u161666.html
Sat Nov 26, 2011 3:34 pm
Where are you located? What type of driving do you do?
How many miles do you normally get out of a set of brake pads?
If you don't want to DIY, I would find a reputable shop to have as your personal mechanic -- so to speak.
Not that I need one at the moment, but I recently found a factory trained Infiniti mechanic that was part of the initial product launch and training program working for an import repair shop near my home. This guy knows Q45s backwards and forwards. The shop's labor rates are very competitive. It takes a little bit of time to find one, but some good independent shops are still around.
Many shops don't mind if you bring your own parts -- that is as long as the parts are correct and of high quality. A shop doesn't want to be bothered with starting and stopping a job due to incorrect or poor quality parts. Also, many shops will let you specify specific brake parts -- and they will get the parts from their local supplier.
A few months from now, I would like to upgrade my Q45's brakes. Recently took the car down a mountain road and experienced an uncomfortable level of brake fade. Also, the brake pads seem to be bad about dusting up the front wheels. My car's previous owner had most repairs done at the dealership -- though that doesn't mean OEM pads were used when the original brake pads were replaced.
Though I haven't owned a Nissan long enough to wear out brakes, as for long wearing brake pads, I have an 06 Ridgeline that is approximately the same weight as the Q45. I understand the OEM ceramic brake pads for that vehicle were made by Brembo.
At 100,000 miles I replaced the Ridgeline OEM rear brake shoes and had the rotors resurfaced. The shoes had about 30% surface area remaining. I removed the front pads to to replace and found the pads had more than 50% surface area remaining. I put the brakes back on and decided to check on the wear level again in 50,000 miles. I think can easily get 160,000 miles from those OEM brake pads that were made by Brembo.
Though I would call it a moderately priced "middle of the road" brake pad, I've gotten a lot of good service from Wagner ThermoQuiet ceramic brake pads.. Also, I can't complain about wheel dusting.
Again, it all depends on driving style for determining the type of brakes to buy.
OwnerCS on Sat Nov 26, 2011 5:16 pm, edited 2 times in total.
