Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Mon Jan 08, 2018 10:23 am
I'm a bit curious how soft brakes got associated with the ABS components. Yes, they're related in a braking sense...but unless a low traction condition exists, the ABS system is dormant during regular braking. If braking feels soft normally, then ABS has nothing to do with it. In fact, if the ABS light is illuminated, about the only thing it does is disable ABS...it wouldn't worsen braking condition, except perhaps by allowing the brakes to lock up under hard braking.
So, what all did repairing entail? Did you need to disconnect the brake lines to repair anything? If so, how long where the lines disconnected, and where they capped when disconnected? Particularly for the rear brakes, usually when I disconnect those and bleed them, I always do a few more rounds of pumping even after the bubbles have stopped...and you'd be surprised how often another set of bubbles comes out. What is the condition of the brake parts? Are you scanning the ABS module to get actual error codes when attempting to fix that problem?
My advice is to fix the braking problem first; ignore the ABS part for now. They are separate issues. It reads like you're throwing parts at a problem. The wheel sensors have nothing to do with hydraulic pressure, except when the ABS module is actually pulsing the brakes to prevent lock-up.
For what it's worth, I have two Nissans—an 04 Pathfinder and 98 Frontier. The Pathfinder has had the ABS light on for a few months, and the Frontier almost always has had the ABS light on and off for, oh, maybe 10 years. The braking in the Pathfinder is superb. The Frontier was braking better before I changed and rebuilt all the brake components; just means I need to bleed it some more.
