onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Tue Mar 04, 2008 2:51 pm
Since it was in storage and was working flawlessly before as you said, have you tried bleeding the brakes yet?
Aside from that, when you can "hear air like noise" when pumping it w/ the car off - try this:
1) Make sure car is off2) pump the brakes a couple times, but the last time, hold it down3) is there still air noise after you hold down the brake?
If there is still noise (i.e. sounds like something is leaking from somewhere), check the brake booster, as it may be busted.
