NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Mon Sep 15, 2003 5:27 pm
2 people . one guy pushing down on the pedal while you open the bleeder screw. once he has the pedal down you close the valve and he pumps it up then you crack it again. do this 3 or 4 times per wheel. start with right rear then left rear then right front then left front. keep an eye on the master cyl fluid level as you do this. do not let it run out of fluid or you'll be starting over. the idea is to bleed each wheel till the fluid flows out in a smooth stream instead of spitting bursts of air out.
