Brakes don't work please help!
HillSideQ45
Car: Model: 1995 Infiniti Q45 Base
Engine: 4.5 L V8 278 hp
Dimensions: 200″ L x 72″ W x 56″ H
MPG: Up to 17 city / 22 highway
So I changed my rear brake pads a week ago and pushed the calipers back to the correct place but when I use my brakes my car goes for another 4 feet before fully stoping do I need to bleed my breaks or what could it be anyone have some suggestions?? I'd be very thankful
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
walk me through every step you took
HillSideQ45
94Q45Beast wrote:
Fri Dec 01, 2017 6:06 am
@94Q45Beast when I changed my brakes I took the calipers off like normal didn't disconnect any brake lines I pushed the calipers back to The position needed in order for brake pads to fit then placed the brakes inside the calipers bolted them back on and pushed the brake pedal Untill it got stiff letting the brakes fully compressed against the rotar
EdBwoy
Did you bed the brakes to break them in properly?
Example - https://www.zeckhausen.com/catalog/inde ... =6446_6443
