beancooker wrote:
You are correct, except, that if you do not open the bleeder valve while pushing in the piston, you take a pretty good risk on damaging the piston and it's seals.
You should also bleed the brakes, to remove any dirty fluid that will be building up in the caliper.
Sorry, I respectfully disagree with this post.
I have the G35 Service manuals and they most definitely do not call for this operation.
The piston has to be pushed back in with a C clamp or the like. If this damages the seals then so be it, the bore in the caliper is corroded.
The hydraulic system is a sealed system and the brake fluid in the caliper should not be dirty. What happens is that the brake fluid is hydroscopic and therefore absorbs moisture, usually at the master cylinder where there is a small vent designed to allow air into the master to compensate for the lowering of the brake oil as the pads wear.
Changing the brake fluid is all well and good to remove any moisture laden hydrauic oil, but you do NOT need to do this when changing pads.
And whatever you do, don't get the brake fluid on the paint work as it is the best paint stripper known to man kind.
OK, I am reading the Service Manual from Infiniti, Page BR-26, nowhere does it say to crack the bleeder open whilst doing front brake pads. In fact, it tells you to monitor the brake fluid whilst pushing the piston home because the brake fluid will return to the MC and may overflow if you topped up the brake fluid at some point.
Modified by james t kirk at 5:31 PM 8/28/2007
