Q45tech wrote:Redesigning ABS, Traction Control and brake system by changing to other than oem pads often creates problems in panic cold wet stopping distances.
Aftermarket pads are only promised to fit nothing else, especially the friction vs temperature curve or the initial friction ramp up rate in the first 1.0 second when you travel up to 100 feet.
The US has no specifications for aftermarket pads unlike oem pads which must meet minimal standards
It is a miracle that aftermarket pads do as well as they do without any actual testing on a vehicle.
Only the guy who rear ends someone accuses the other guy to be at fault for stopping to quickly.
is their anything special you need to bleed the brakes on the m? like on some cars you need a scan tool to actuate the absM4T5 wrote:I prefer doing them myself. If your comfortable with Goodyear's services then let them do the brake job.Also, how many miles are on your car?? One thing they may also recommend is a brake flush. This is recommended over 30Kmi or whenever your first set of brake pads need replacement. You can either let them do it with their aftermarket type fluid or just go to a Nissan dealership and have them perform the brake flush. Not sure if Nissan would be any cheaper than Infiniti, but others seem to make it out that it is.Both will use the same products in your Infiniti.
J
You really know nothing about maintenance do you???Fluids break down and so do there chemical counterparts.The brake system is subjected to a lot of heat. The fluid will break down. The anti corrosion additives break down as well. This keeps the internals free of corrosion. Keeping the internals of a brake system in top condition should be a great priority to any auto owner. The sad thing is...like you and many others, they neglect maintenance due to ignorance or just not caring enough about their condition of their vehicle.Do what "YOU" want with your vehicles. I just feel sorry for those who own them after you!GJEMD wrote:"One thing they may also recommend is a brake flush. This is recommended over 30Kmi or whenever your first set of brake pads need replacement."
flushing modern brake fluid @ 30,000 miles is about as important as making sure all the labels on the soup cans in your cabinet are all facing forward
Brilliant people so often try to find the cheapest and thereby best repair without considering the side effects.Q45tech wrote:It is a miracle that aftermarket pads do as well as they do without any actual testing on a vehicle.
I've done hundreds if not thousands of brake jobs, both with resurfacing, replacing rotors, and just a simple pad slap. Infinitis specification for lateral runout is 0.005", any more and replacement is recommended. Many people with never notice variance of up to 0.008-0.010" .Removing 0.006" from the rotors and giving it a non directional finish will give your brake pads the chance to break into the rotors correctly. There is a chemical exchange that happens when the rotors come up to temperature and you properly bed the pads to the rotors you will get the best results from your brake job. I got lazy one of the last times I put pads on one of my cars and didn't resurface, the brakes felt the same and seemed to fade faster. The following weekend I filed down the pads, resurfaced the rotors and match mounted them to the hubs. I'm telling you not as a dealer tech but as an Infiniti connoisseur a proper brake job will yield results that are worth the work/money.M45Caliber wrote:IS IT NECESSARY to machine the rotors when changing out the pads?
how many times have you flushed the brake fluid??audtatious wrote:Hmmm...I tend to agree with Q45Tech and Steve. I have 140k on my Maxima (same set of rotors BTW ) and have obviously had the brakes done a few times. With aftermarket bads (mid line and even the high-end pads I've tried) I was not happy with them, they were noisy and the pads wore faster. Since letting Nissan replace them with OEM pads I have been happy with pedal feel and lack of noise.
That's a good non biased way to put it. Makes sense when you think about it.M4T5 wrote:There is no easy answer to this one. Front – Rear braking has many different configurations. You have rear discs and rear drums. Sometimes your front and rear brakes are evenly matched and many times they are not. You may see 12” rotors, front and rear or 12” front and 9” or 10” rear. Many times you have metallic front pads with organic rears. Hydraulic pressures also affect the mix. Fronts run 800 to 1000 psi and rears 400 psi or less.
So your saying when your pads where almost completely worn out your brakes sucked? That's usually how it goes. Hawks may indeed work for you if you race your M or drive aggressively. As stated several times in this thread, 99% of drivers will never have an issue with the OE brakes.YMm45 wrote:i must disagree with saying that aftermarket pads don't compare to oem factory i have used hawk pads all my like on all my cars this includes two drag cars i can honestly say that they are way better then the oem pads i had on the car i had about 3 months of wear left on my pads said per the dealership and everyone that drove my car said the same as i did it stopped horrible it had a slight shake in it after changing the pads to hawk pads and turn of the rotors and its night and day i would suggest just do your research on your pads i wont just put any pads on my car
On my cars, every 30k miles or 2 years ... whichever comes first.GJEMD wrote:how many times have you flushed the brake fluid??
