brakes beside Z32
ilkhan
what brakes can you upgrade the stocks from w/o going to 5 lug? More stopping power is nice and I would rather not have to put out for a 5 lug conversion if I dont have to...
speaking of which...how much does a conversion cost? Maybe it is worth it...but would prefer not to if I can find 4 lug wheels and a good set of brakes w/o doing it.
The Mic
Car: 3Z Wmb
porsche or bentely (sp?) thatd be really cool if i had porsche brakes
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
top hat sell the rotors so you can do the z brakes but stay 4 lugthats what im getting.
A_Rivers
Car: 1998 Honda CRV, 1996 Yamaha FZR600
I have Q45 front brakes on my car (1991 240SX) that cost me $70 out of a junk yard and Powerslot Slotted Front Rotors for about $180. The best thing about these are that they fit in the 15" stock wheels and are very cheap. They also use the stock brake lines and offer a good balance if you keep the stock rear brakes. Here is a link to my write up after I did my 5 lug swap. I also just got thru installing a 300ZX Master Cylinder and stainless steel brake lines this weekend so I am Officialy done with the braking side of my car. DO NOT! get the VGX semi metallic brake pads, there are peices of s***. They heat up way to fast and fade after a few hard braking stints.Here is the link.
Aaron Rivers
240SXedUp
POS_S13
Car: thizzlamics
A_Rivers wrote:I have Q45 front brakes on my car (1991 240SX) that cost me $70 out of a junk yard and Powerslot Slotted Front Rotors for about $180. The best thing about these are that they fit in the 15" stock wheels and are very cheap. They also use the stock brake lines and offer a good balance if you keep the stock rear brakes. Here is a link to my write up after I did my 5 lug swap. I also just got thru installing a 300ZX Master Cylinder and stainless steel brake lines this weekend so I am Officialy done with the braking side of my car. DO NOT! get the VGX semi metallic brake pads, there are peices of s***. They heat up way to fast and fade after a few hard braking stints.Here is the link.
Aaron Rivers
did the q45 calipers bolt up to your stock mounting brackets?
93RPS13
Car: Cars, Girls, Cars, Food
yes it does
A_Rivers
Yes these will bolt up to the original mounting brackets.
Chingon
Car: 1991 and 1992 hatchbacks
big red or big black porsche brakes.....from 996tt and 964 s4 respectively. or wilwood somethinglites w/custom mounting bracket.
barrigas14
have seen porsche, endless, wilwood, project mu, z32, GTR, q45, and brembo.
would be tight to see Ferrari or some exotic cars brakes like that.
93RPS13
Aaron Rivers
how hard is it to lock up the q45 brakes with stock rear? thanks
Chingon
actually the big red and the big black are made by brembo and am pretty sure is the same caliper used in the f40 or f50 ferrari.
