Brakes and Suspension Q's
adamtsiw
Car: 93 240 hatch
Hello to all that read this. I'm new here and just wanted to see if you guys
could help me out. I recently purchased a 93 240sx hatch and really love
the car it has a few little goodies here and there on it But there
is one problem with it that I just can't seem to solve. When I brake I can
push the pedal down about a 1/4-1/2 of the way down and it brakes
straight, but once the pedal gets much farther than that the car wants to
pull the steering wheel to the right in order to keep braking straight. It's
led me to believe it's a bushing because it doesn't do it from the beggining
of the brake pedal travel. If you guys have any specific things I could check
it would be greatly appreciated.
Thanks, Adam
adamtsiw
Car: 93 240 hatch
Well today since it was so nice out I decided to check the brakes, and the
drivers side rear brake is really weak hopefully tomorrow I can figure out
what is going on with it. Hopefully a brake hose clogged up or something
along those lines. Any suggestions would still be a great help
r3v_v3ng3
Car: 91 fastback ka-t
try bleeding the brakes
modulation
It seems like the opposite side it is pulling to when braking might have a seized caliper?
adamtsiw
Car: 93 240 hatch
Well I brought it into my brakes class on monday and I realized that the drivers rear caliper was leaking. The square cut o-ring inside had a little spot where it was by-passing fluid. I bought a rear caliper rebuild kit for both sides on monday, it came in today. So today I went ahead and rebuilt them and now it doesn't leak. None of the slides on the calipers are siezed up, they all move nicely. I figured after all of this it would solve my problem... but it didn't. Today it's raining here so I took her out and locked them up a couple times and it still wants to pull. It seems that the front right is locking up before the left... so thats my new mission. Figure out why this is happening. When I bled the brakes after rebuilding the rear calipers, it had good flow at each corner. So I'm not really sure what's going on, but since it was so cheap to rebuild the rears I guess friday in class I'll rebuild the fronts too. Hopefully that will solve my problems. If you guys have any suggestions though I'm all ears. Thanks for all the previous input
johnnyballs180
Car: 1990 240sx
my first guess would be a leaking caliper on the opposite side it's pulling towards, the left in this case, and i got a second opinion too. further, if you checked all your pads and the time's coming up to change them soon, you might as well, front and back. i betcha this will fix your problem, and at worst you isolated some variables.good luck! don't hit any guardrails
