brakes again
bent240LV
i just want to make sure im doing everything correct everyone takes different approaches doing the 5 lug swap . i would like to know if the whole 300zx parking brake drum assembly will fit onto the s14 5 lug hubs in the rear or do i need to use the 300zx hubs and up rights so for the fronts i need the s14 spindles w/hubs and bushing from s14 pushed into s13 lca. and that it right besides the obvious new brake lines for 300zx calipers front and back
And for the backs do i just need the hubs or the spindle also from s14. Also does anyone know if it matter if you get spindles from an s14 w/abs?thanks for the help i have searched but you get a lot of different information and soemtiems does not answer all your questions
bent240LV
somebody anybody ? ah loose money
[s3]
[s3]
