Brakemotive Kit
Twizz
Car: 2007 M35X - Stillen exhaust, Injen CAI, dropped on Espelir springs, Morimoto 3K Hid Fogs, Morimoto 6K low beams, Full interior and exterior LEDs, air horn, 35% tint all around(45% on the windshield)
Hey guys. Im looking into the brakemotive kit. I was wondering if there is a rust issue with this kit as I have seen with others ?
donnieb83
Car: 2007 M45S
No rust issues with mine. They are zinc plated. I'm located in TX also so mostly just dry heat here.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
beginning to see just a little bit on the outer rim of the rotor and a little more at the hub, but waaaaay less than OEM.
Plus, I've got at least 30k miles (> 2 years) on mine.
merlinq2
Car: 2007 Infiniti M35x
lots of rust on mine, surface is excellent, and the wear has been excellent. This is year two and they look fine, all I need to do is re and re the front and rear pads. I live in ontario canada harsh winter so my assessment is based on a harsher climate. They are the best deal and you get great service from the brakes and the supplier.
Minus (-)
Car: 08 M35x
I say pull the trigger on it....the inner circle on my oem ones look like the barclay center lol
Twizz
Minus (-) wrote:I say pull the trigger on it....the inner circle on my oem ones look like the barclay center lol
Really ? Mine are as though I just put them on (looks wise). I only started to ask because the OEM pads are $100+. I wound up buying some from infinitipartsonline.com for $88.
Twizz
I called an spoke to someone at BrakeMotive and they told me that the rust would be determined by the weather. She said she lives in AZ where the temp is warm with a dry heat. Being that I live in NYC, the terrible winter and humid summers don't bode well for these rotors. I will see though once the pads I ordered run out
EniGmA1987
Car: '06 Infiniti M35 Sport
If the Brakemotive rotors rust on you then just about any rotor will rust for you.
Twizz
EniGmA1987 wrote:If the Brakemotive rotors rust on you then just about any rotor will rust for you.
My factories havent and Ive had the car for over 2 years now
Ilya
I live in NY and they rust, but not as fast as most others.
It's the downfall of living in this crappy state.
Twizz
IlyaKol wrote:I live in NY and they rust, but not as fast as most others.
This is true. I would imagine that upstate would be even worse.
PlatinumM35
Car: 2006 Infiniti M35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
In live Florida and my rotors rust. Every now and then I clean them with naval jelly. It removes the rust. All and all I would rather have a little rust than warped rotors over and over. Those OEM ones suck sincerely.
Twizz
PlatinumM35 wrote:In live Florida and my rotors rust. Every now and then I clean them with naval jelly. It removes the rust. All and all I would rather have a little rust than warped rotors over and over. Those OEM ones suck sincerely.
Where could I get this naval Jelly ?
