Brakemotive install
patmcd06
Car: 2007 M35x
Hello,
I just had a friend install front and rear Brakemotive kit with 2 new front wheel hubs in my 07 m35x. He has his own shop, and has always done great work for me. My question is that my new brakes are scrapping a little. Is this normal during the break-in phase with Brakemotive?? Just wanted to check before I bring it back to him.
Thanks,
Pat
kmiles
Car: 2015 Q70 3.7 AWD - Hermosa Blue
Sold - 2007 M35x
I installed my first set over 3 years ago and they've never made a scraping sound. I have my next set in the garage, waiting for me to get around to installing them. I'm not a brake expert, so I'm not sure what would cause that sound.
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
patmcd06 wrote:My question is that my new brakes are scrapping a little
Squealing a little? - yes. Scraping sound - no.
I've done 2 sets of Brakemotive rotors and pads on my '06 M45.
by no means an expert, but one of my friends showed me how to do it - easy peasy, even without a lift or air tools.
Need to make sure you bed in your pads - generally about (5-10 stops from about 50 mph to almost stopping, but NOT stopping)...you can search the threads on here for some more detailed steps if you want
Scraping:
1. did he use the OEM pads, aftermarket, or the Brakemotive pad...reason I ask is that some certain types of pads need the shims, the Brakemotive kit has the shims already on the pad itself.
2. sare the pads sitting right? I've sometimes noticed that the pads can sometimes shift a little as you are putting the caliper back on.
3. Did he grease the caliper pins? might have a sticky caliper.
Craig
EniGmA1987
Car: '06 Infiniti M35 Sport
^^^ My guess is with the age of the car it is probably a sticky caliper too.
patmcd06
Car: 2007 M35x
yes, he used the brakemotive pads also. The pads look like they are sitting properly.
To clarify, its more of a rubbing sound than a scraping sound. What is the cure for a sticky caliper? Remove the caliper and grease the pin??
pedsemdoc
R2C Intakes
Oil catch cans
patmcd06 wrote:What is the cure for a sticky caliper? Remove the caliper and grease the pin??
hopefully it's something as easy as that - sometimes the caliper pins get dirty or rusted
or could be a problem with the piston itself, or a problem with the brake line
is it both sides? or just one side?
