ZiG »
https://forums.nicoclub.com/zig-u45755.html
Mon Nov 05, 2007 11:22 am
Ok, just take it step by step. First see if there is resistance between the bulb socket and the ground. No? Good, then your ground is fine. Now check to see if there is voltage at the bulb socket with the pedal pushed. No? Ok, check it at the switch.. Make sure there is voltage to one side of the switch. If there is, then check the wires from the switch to the bulb socket. If there isnt power to the switch, check the wiring from the battery to the switch.
Take it real slow and methodical, and by the logical process of elimination you will arrive at the problem.
