I put quotations around "warped rotors" since there is some debate whether or not rotors physically warp or some say that a layer of brake-pad is transfered to the rotor also causing the same sensation.
Either way, I'm changing out my rotors, but I wanted to know if I need to change pads as well?
Is there anything additional I need to do to the rotors or current pads on the truck?
The pads are still in very healthy condition, I think they have about 5-7k miles of commuter driving on them. I got my truck early 2011 this year, and the previous owner claims he changed the brakes, but not the rotors. so the pads are healthy, and I don't want to chuck them out if I can avoid it.
But if it is advisable that rotors and pads be changed together, then I'll need to consider pads as well (which will lead me to researching this forum which ones are better suited).
Thanks for any advice and input.
And I don't think it matters, but this is for a 2001 Infiniti Qx4 4wd.
I barely tow or go offroading. I just drive it because I loves it!
