Brake woes
240SXedUp
Ok. So I got fed up with my rotor/pad swap so i decided to bring it somewhere. I asked a couple people from here if it would ok to not drive with 1 of the calipers on because i couldnt get it back together and some of you said it would be ok. I drove from my house to tire kingdom. It was about a 4 minute drive. So i go back like 3 hours later and they're closing up and the guy says im going to need to get a new caliper. Is that right? Cuz i asked a few of you on AIM and you said it wouldnt be a big deal.
240SXedUp
bump i really need ur opinion
xyster
Car: '00 Prelude
My driver's side caliper bolts managed to walk themselves out once. I drove around for a few days listening to a weird "thump thump thump" coming from that wheel. I figured the tire was just wearing out, but when I pulled the wheel off, the caliper was hanging off completely. I put it back on with new bolts, and have never had another problem with it. You can't trust professional mechanics. Everytime I've taken any car in for a brake job, they try to tell me I need new calipers.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
tire kingdom is pure garbage...i went into NTB the other day to talk to them about an alignment....i saw that they are a sect of tire kingdom and i walked out in mid sentence
240SXedUp
Hahaha. So thats a no on the calipers?
240SXedUp
I mean how could i prove them wrong?
xyster
Car: '00 Prelude
why bother proving them wrong? Just say "don't replace my caliper. If you're not ok with that, I'll go elsewhere."
240SXedUp
Ok... what if they say "the piston is messed up, we cant get it back on"
240SXedUp
Do i just drive out with 3 calipers like i did before?
240SXedUp
Just dawned on me... you think they tried to turn back the piston and broke it themselves?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
my friends pad fell out somehow from his front drivers side, he was driving with on pad on the wheel for a while, when he took it in they said he needed a new caliper cuz they coudn't push the piston back. so i dunno, they might be telling the truth they might not
Silent Drifter
Car: '93 Nissan hatch
'90 Nissan coupe
'96 Ford Ranger
Looking for a bike!
adam would u just drive down here an well get them brakes on for you.
240SXedUp
So is there a way that I could have broken the caliper? Cuz if hes lying to me im just gonna go down there and tell him to put them on
SloS13
You cant just leave the hydraulic line hanging there. As soon as you try to brake, all your hydraulic fluid will spew out.
240SXedUp
What do you mean. I guess you guys should know where the caliper actually was... it was strapped to the body next to the wheel. And the brake line was still on.
BoostFab
Car: S13cp, S13fb, S14z
i would do all my brake work.
(if i understand your problem correctly)your caliper(s)probably is pressurized (lock). mine did the same, it just wouldn't depressed. this cheap little "Caliper Spreader" does the trick:
SloS13
240SXedUp wrote:What do you mean. I guess you guys should know where the caliper actually was... it was strapped to the body next to the wheel. And the brake line was still on.
well, if you are going to drive home, the piston is gonna have to be in the caliper, and the caliper is going to have to be spread...STRONG. I wouldnt doubt a caliper could crush wood. If you didnt have it spread (unless the piston was VERY rusted in), the piston will pop out as soon as you touch the brakes and bye bye fluid
240SXedUp
Well they said that the piston is gone
SloS13
well, you're SOL unless they can cap that brake line
240SXedUp
I guess i need a new caliper
DammitBobby
Car: S13 91 KA24DET
Wouldn`t it be cheaper for you to just buy a caliper and do it yourself. If it were me I would buy both sides Q45 caliper and rotors. That way u get a brake upgrade that has 2 pistons instead of one. I checked out Autozone and you can get rebuild ones for 90 a set and the rotors were only 35 a piece. Only thing there is a core charge. I don`t think they are smart enough to figure out what core you gave them.
fastblue240sx
Car: cars, video games, racing, drifting, etc.
I had a problem with my caipers locking up whilst going down the interstate. SUCKS!!!!!!! Sudden stops from 75 are not cool at all! I've now replaced both of them and still have no idea what the hell was wrong with them in the first place. All I know is, I don't ever want to replace another one for the rest of my life cuz I'm really tired of that crap.
Trevorcrx
Car: none
nothing is free
180fan
Car: 89 fastback
fastblue240sx
have you checked the grease in your brake pins? Also check the seals around the piston themselves. If the new calipers aren't seizing up, then chances are it was the rubber seal that goes around the piston inside the caliper.
fastblue240sx
Hey 180fan......the old calipers were pretty rusted and I couldn't get the piston to move at all. And believe me, I tried everything to get the thing to go in. I just went on ahead and replaced them cuz I got tired of dealing with them.
180fan
Car: 89 fastback
Oh ok. Well about the piston, you should have just replaced the piston, and gotten a new seal kit. There's an inner o-ring that needs to have the red grease put on it. After you do that, you need to lube the piston with brake fluid in order to get it to slide in. but that's after getting the boot on the piston, and greasing the lip and the inside of the boot for the piston itself.
